Home > Technical > Intermittent Suspension Fault
chapman_i.t
2005 Range Rover Sport TDV6 HSE Java Black
lo all,
I am getting an error on the dash intermittently saying "Suspension Fault, Ride Access Height Only". This is very intermittent and comes on at any time, sometimes it doesnt come on at all on a journey.
Also if I turn the engine off and back on the error goes away, I can still use the air suspension at this point?
Any ideas guys what could be causing this?
Thanks
James
Post #306845 Wed Jul 20 2011 9:36pm
chapman_i.t
Nobody had this fault then? Sad
Post #307395 Tue Jul 26 2011 4:02pm
you got either:
a dry joint/chaffed wire in the loom
or
a dodgy sensor on it's way out
Sorry to say it but it'll eventually get worse and you'll get a full "suspension lowering reduce speed, special programs turned off" red light of recovery...dash error. Big Cry
Very hard to trace for the dealer too.... RRS gone
Post #307397 Tue Jul 26 2011 4:08pm
chesterfield
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
If you are able to get the fault codes then it may shed some more specific light on the issue. Im guessing you will need a dealer to read the fault codes for you, or on some vehicles you can plug in an ODBII reader to access these codes yourself. I have one which connects to an in car pc system via bluetooth on another vehicle (350Z) and I can inspect for any fault codes myself - which can save a fortune on dealer costs.
Not been on this site long, and I am only picking up my first RRS on Thursday, so not had chance to research whether this type of thing is available for the RRS - there may be a friendly local with access to reading equipment that can help out?. RRS 3.0D HSE 11MY - Fuji White, a few extras.
Post #307399 Tue Jul 26 2011 4:37pm
Stefan6666
2005 Range Rover Sport Supercharged Java Black
I experienced something similar and it got worse and I got the red suspension light(as someone posted before)
My dealer told me that these things need to be replaced:
1-Chassis Filter
2 - Shut off valve
1 - Sensor
1 - Coil
Post #307627 Thu Jul 28 2011 5:52pm
dhenz70
there is a small leak in the system
Post #311765 Sat Aug 27 2011 8:31pm
ELD70
Normal suspects:
Dodgy brake light bulb or possibly brake pedal switch...
Post #311766 Sat Aug 27 2011 8:49pm
simon1233
When mine did this it was a fault in the loom. They can do resistance checks on the loom to identify the faulty part then replace the offending wire. Mechanics these days are becoming more like computer technicians
Post #311767 Sat Aug 27 2011 8:59pm
chapman_i.t
Ironically,
I have since washed the car with a jet wash under all arches and given it a thorough clean.
Since then the error light has not come on in 3-4 days, where as before it was coming in every day.
Is it possible I could of cleaned something with the jet wash on one of the sensors or something? As now I dont have the error message at all.
James
Post #311787 Sun Aug 28 2011 11:19am
RRSSS
Bahrain 2010 Range Rover Sport Supercharged Nara Bronze
I've been getting a similar warning message on the dash for the last couple of months:
So decided to take it in to the dealership to try to fix it.. Obviously sod's law applies here, whereby none of them could see the fault Sad
Anyway, they mentioned about upgrading the software and hopefully it'll be fixed.. Been driving it again for almost a week now and (touch wood) it hasn't returned...
Post #311798 Sun Aug 28 2011 3:50pm
drdelrrs
You have a faulty earth on a light unit.
Post #311806 Sun Aug 28 2011 7:05pm
dhenz70
A month ago we encountered that problem, The dealer already replaced the drier kit as for the dtc C1A13-64,unfortunately suspension fault still there (access mode only,reset suspension when height is clear,etc),We found out that the air suspension was faulty.Good day Very Happy
Post #311907 Tue Aug 30 2011 7:59am
gmilner
Australia
I was getting exactly the same message regularly. Took it to the dealer and they replaced a suspension compressor. Problem solved. Greg Milner
Perth, Western Australia
2010 RRS 3.0. For towing boats and bashing corrugated outback roads.
2007 Audi TT Quattro (wife's shopping cart. Time to go)
2013 Polo GTI (wife's new shopping cart.)
2007 Holden Caprice V8 ('cos it's not worth selling it)
Post #312072 Wed Aug 31 2011 1:32pm
chapman_i.t
Faulty earth on light unit?
Post #313546 Tue Sep 13 2011 10:16pm
RRSSS
Are these comments directed at my problem (ie. for the images I put up)?
Suffice to say, my problem is back, and the dealer seems clueless as to how to solve it Sad
Post #315446 Wed Sep 28 2011 9:00am
