![]() | Home > General > DIESEL FLAP WONT OPEN |
| Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495
I think there is a manual ring pull in the boot. If you open the right hand side cover thingy you may find it there.
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
I found the rubber sucker cup used to change spot light bulbs worked a treat when my catch broke. RRS gone
| RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176
I had a similar problem to this on mine. For me the problem was that there is a little black plastic bit on the flap that comes off sometimes. LR Engineering at it's finest. |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
A search would have brought you toTHIS file in my Gallery! |
| jrinns Member Since: 10 Dec 2010 Location: Midlands Posts: 88
When mine stuck , I pushed it in and pressed unlock on the keys. Seemed to work |
| Stephen Member Since: 15 Jun 2010 Location: West Sussex Posts: 30
I currently use my credit card to prise it open until the replacment rubber bit that helps it pop open arrives at my local dealer. |
| V8KIP Member Since: 09 Dec 2010 Location: Kent Posts: 18
Mine used to do this, I used to have to lock/unlock using the keyfob to get it open. Then I sprayed the bit which releases with WD40 about 3 months ago and it hasn't done it since |
| Stealer#1 Member Since: 05 Jul 2011 Location: South Posts: 4 |
Just yank it open, apart from little ******* putting stuff in u can't get fuel out.... |
