Home > Technical > Prop Shafts
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Prop Shafts
What are the issues and implications of the prop shafts not being straight?
Post #264220 Mon Apr 26 2010 5:53am
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
Depends on how badly and for how long. From vibration through the chassis, to throwing the car offline and chewing out the UV joints, possible diff failure and a nasty hole in the bottom of your car ......
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #264222 Mon Apr 26 2010 6:45am
2nd Rower
Thanks Gordon,
Not sure about those two points TBH..
What causes prop shafts not to be straight in the first instance?
Post #264223 Mon Apr 26 2010 6:59am
BKHK
Australia
Misaligned from factory or damage from off road use I would imagine. Maybe that's the cause of your vibration 2r. Remember, I had vibes from a rear diff on my last RRS so a mis aligned shaft causing diff issues could be a problem. Take it to your favourite LR dealer for a check before your warranty runs out.
Post #264238 Mon Apr 26 2010 9:10am
avartis
2006 Range Rover Sport TDV6 SE Rimini Red
Could also be your engine mounts are worn out (engine vibration felt in the cabin when waiting at the traffic light in Drive with brakes applied) and also your transmission mount. This causses your transmission to move by a few centimeters to one side and as the transfer box is attached to it, it will also move straining your front/rear shafts.
I changed my 2 engine mounts and the transmission mount and problem went away, much niser ride.
Post #266320 Mon May 17 2010 3:11pm
