Home > Technical > Prop Shafts |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
What are the issues and implications of the prop shafts not being straight? |
Mon Apr 26 2010 5:53am |
Thanks Gordon,
Mon Apr 26 2010 6:59am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
Misaligned from factory or damage from off road use I would imagine. Maybe that's the cause of your vibration 2r. Remember, I had vibes from a rear diff on my last RRS so a mis aligned shaft causing diff issues could be a problem. Take it to your favourite LR dealer for a check before your warranty runs out. |
Mon Apr 26 2010 9:10am |
avartis Member Since: 10 Sep 2009 Location: UK Posts: 18 |
Could also be your engine mounts are worn out (engine vibration felt in the cabin when waiting at the traffic light in Drive with brakes applied) and also your transmission mount. This causses your transmission to move by a few centimeters to one side and as the transfer box is attached to it, it will also move straining your front/rear shafts.
Mon May 17 2010 3:11pm |
