Home > Maintenance & Modifications > Which Jet Wash
ASH555
England 2010 Range Rover Sport 3.0 TDV6 HSE Zermatt Silver
Which Jet Wash
In the market for a jet wash for cleaning my vehicles, can anyone save me some time and money by recommending one?
Thanks Thumbs Up
Ash MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
Gone 2006 '56' 2.7 TDV6 HSE, Zermatt Silver, 20", Side Steps, Brembos, Dynamic Pack, Etc
VW Transporter, 19" Rims, T32 170 BHP, Lowered
Post #261502 Tue Mar 30 2010 2:13pm
Bradders
IMHO cant go wrong with any of the Karcher range. Ive had mine for about 10 years and its had some serious, weekly abuse between washing cars, patios and paving and its still going strong. I think you gets what you pays for! FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #261503 Tue Mar 30 2010 2:19pm
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
Hmm, I've had several Karchers and none of them have lasted that long without needing to be repaired. I wouldn't recommend them over the other makes but at least they are easy to get fixed.
They are great pieces of kits, lots of uses around the home/garden. I'd recommend getting one with all the accessories included such as the patio cleaner attachment as they are expensive to buy on their own. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #261506 Tue Mar 30 2010 2:34pm
RichardM
How about this:
http://www.autoexpress.co.uk/products/prod...ested.html WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #261507 Tue Mar 30 2010 2:36pm
JFK
2008 Range Rover Sport TDV6 HSE Java Black
Im with Bradders & Richard, Got 1 at home & 1 @ work both get good use & have never let us down. Also agree that you need to get as many `bits` in the box as you can. I couldnt believe how much a lance was, does not seem to be as good as the one it came with either. Rolls Royce Ghost, RRS 2.7 TDV6, E220 Avantgarde Estate.
Post #261511 Tue Mar 30 2010 2:56pm
JimboTD5
England 2008 Range Rover Sport TDV6 S Buckingham Blue
Hi
I personally would opt for the Karcher equipment, I have had one for years and like the others it gets regular use on cars, caravan, drive and patios, I would not be without it. I agree that the accessories can be expensive, I had to renew my patio cleaning lance and it cost me £40 which I thought was a bit of a rip off , but it was from Halfrauds!
If you have a Costco card I would buy from there as you will get a good deal and if it should go wrong just take it back, I have taken things back which I have had for 2 - 3 years and they have always given me my money back without question.
Jim
Post #261516 Tue Mar 30 2010 3:51pm
I've had karchers and each ones blown on
me
I just bought a Nilfisk alto E140 from www.cleanstore.co.uk for £202 including patio cleaner, lance brush(for the caravan not the car)
It's not All about the power of the jet but more to do with flow rate, higher the better,
Post #261519 Tue Mar 30 2010 4:28pm
Also check specs on pump, some karcher cheap models have plastic pumps and parts which is why they fail so often
Post #261521 Tue Mar 30 2010 4:59pm
ASH555
Thanks guys
Which Karcher model do people have?
NPinks thanks for an alternative
Thumbs Up MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
Post #261535 Tue Mar 30 2010 7:32pm
JimboTD5
Guys
Regarding the issue with the Karcher "blowing" I had this problem a few years ago which resulted in me taking three washers back to Costco in one day!
Eventually after speaking directly to Karcher technical in the UK it turned out that the problem was caused by my hose having a cutoff valve to enable me to change spray heads etc without turning the water off at the tap. As soon as I removed the valve from the hose the problem was cured, been using the same unit for years now without issue. Unfortunately there was no mention in the manual about not having any one way valves on the hose!
Jim
Post #261537 Tue Mar 30 2010 7:44pm
rabbutler
Scotland 2010 Range Rover Sport TDV8 HSE Alaska White
Got Karcher too, was quite an expensive one £270, bought over 7 years ago, it has frozen solid on various winters but defrosted without splitting anything. You gets what you pay for, will def buy another when the time comes Thumbs Up 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack
Now gone - Jaguar XKR4.2 v8 Supercharged
Gone - 08 RRS TDI V8 Java Black, Privacy glass 315 BHP tunit box.
Still have - Merc C200 sport
Yahaha FZ1000
Gone - BMW X5 3.0d sport
Post #261544 Tue Mar 30 2010 8:12pm
I have heard of the hoselock restrictor valves causing problems, I gave them without that way it doesn't restrict water flow too
Post #261546 Tue Mar 30 2010 8:55pm
The karcher I had was a KB4040, still got it, going to look at cost to repair then eBay it To some sucker Whistle
When I was looking and was undecided I found these two karchers giving good spec's
I liked the idea of the garden hose reeling on the k6.75 and another one I nearly went for K7.85
Post #261547 Tue Mar 30 2010 9:02pm
rabbutler
The K6.75 is the new versionof the one I have, everything rolls up and out of the way, I have an extension hose attached to my one and it rolls up too, good piece of kit Thumbs Up 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack
Yahaha FZ1000
Post #261548 Tue Mar 30 2010 9:13pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
I have the K7.85 and had it for more than 3 years this winter was the only time I had a problem when the water in the hose froze and burst the lance, replaced it and it works fine. I too have a hose without a cut off valve just for use with the K7.85 I also have a filter in line with mine as I have a well that provides water for most of the services in the house and sometimes a little fine sand comes through and I don't want to sand blast the car! Sons of dogs come hither and get flesh
Clan Cameron
Post #261595 Wed Mar 31 2010 8:05am
