Home > Technical > Bluetooth now not working |
KevinJM Member Since: 16 Dec 2005 Location: Belgrade this week Posts: 120 |
used happen to me on my 2005 TD6 - simplest solution was to disconnect and reconnect the positive terminal on the battery for a second. It then reset itself. Hardly a hi-tech solution for such an expensive car but what can you do? try it anyway and see what happens RRS TDV6 (gone)
Fri Dec 04 2009 5:39pm |
Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285 |
Thanks for that Kevin, just went out to try it again, and guess what it now works had to put code in again to get it to connect, didn't give me that option yesterday, just kept trying to connect but couldn't see the Landrover device.
Fri Dec 04 2009 5:54pm |
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 |
Tried all that and the fuses, eneded up having to get a new bluetooth moduel. If that is the case go to Nick at yeovil LR he was the cheapest.
Fri Dec 04 2009 9:57pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Popping the battery terminal resets a lot of other stuff too - best off with a SW disconnect / delete & re pairing IMO |
Fri Dec 04 2009 10:16pm |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
Iphone? |
Sat Dec 05 2009 3:56pm |
Sat Dec 05 2009 5:59pm |
hario69 Member Since: 06 Jan 2009 Location: Teesside Posts: 68 |
What does a SW disconnect delete and re pair involve step by step? Sorry for my ignorance! |
Tue Dec 15 2009 10:09pm |
