Home > Technical > Not the usual knocking noise
wullie
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Hi Guy's
I have a 2006 sport hse 67000 miles, I have a continuous light knocking noise from both front and rear of the car, even running over normal - slightly rough roads loaded or not the noise is always the same level. At first I thought it was maybe the shocker bushes ( same sound ) ?? Does my 06 car have body shockers as the later models do?? any ideas would be of great help. Confused
thanks
Wullie
Post #243706 Wed Nov 25 2009 5:48pm
rrsjo
This all point to the anti roll bar bushes having worn. Have you had these replaced with the modified part? Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #243743 Thu Nov 26 2009 10:54am
Charlie Crocker
See link for fix (successful in my case)
http://www.rrsport.co.uk/forum/topic15691.html
Post #243754 Thu Nov 26 2009 2:09pm
wullie
Thanks guys, do you know how much this TSB cost, I dont know what has been replaced on the car yet (bush wise) Ive not had time to look at it. Do you think this TSB would help on my RRS?
cheers
Wullie
Post #243768 Thu Nov 26 2009 5:06pm
Charlie Crocker
It is likely it will make a difference. If it doesnt make a difference then there is likely to be a worn component which the dealer could diagnose using bulletin LTB000204v4 if you can find a dealer thats any good. The bulletin is written in order of most likely causes. First up are the front lower control arm ball joints so you should start there.
In terms of the masses in the link, i can't see that these would be that expensive, mine were done on warranty so i didnt get to see the bill, but they are 1 casting and two nuts and bolts each side so not much too them
Post #243810 Fri Nov 27 2009 8:31am
wullie
Can someone put a link in this post for the bulletin LTB000204v4, I have the bulletin LTB00241, I will have a go at diagnosing the problem myself, Landrover agents around me are usless , this help is much appreciated Thumbs Up Is there a CD type manual out for the RRS yet?
cheers
Wullie
Post #243844 Fri Nov 27 2009 1:57pm
Leo
Kenya
Not a CD, but you can sign up to LR Global Technical Reference, which covers most things.
Post #243959 Sat Nov 28 2009 10:41pm
wullie
Interesting Leo but do you have to be a dealer to register. Confused
Wullie
Post #243978 Sun Nov 29 2009 6:32pm
Micrometer
United Kingdom 2010 Range Rover Sport Supercharged Java Black
No, any one can get it - you have to pay though of course!
There is a guy (bobby) on here who has posted them up before - might be worth a go. Trust me, i'm an Engineer!
Post #244035 Mon Nov 30 2009 3:21pm
wullie
Any chance Bobby could post the bulletin LTB000204v4 if at all possible, thanks
wullie Bow down
Post #244060 Mon Nov 30 2009 10:27pm
wullie
Hi folks
Thats my knocking gone for now, I fitted the anti-roll bar packers and bingo noise gone, per Tech Bulletin LBT00167. When the weathers a bit better I will fit the later bushes, but what a differance with just the packers fitted. Both top nuts on the anti-roll bar clamps were very hard to get into had to remove some surrounding parts to get into them, so with some sweary words now and then I got it without the landrover tooling. Thumbs Up
Wullie
Post #254206 Sun Feb 07 2010 6:07pm
Micrometer
Wullie, Does your car not have dynamic response on it? i thought all HSE's did. Trust me, i'm an Engineer!
Post #254997 Thu Feb 11 2010 3:00pm
wullie
Hi
No, think it was from 07 on glad I dont have it.
cheers
Wullie
Post #255239 Fri Feb 12 2010 7:54pm
