Home > Technical > Not the usual knocking noise |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
This all point to the anti roll bar bushes having worn. Have you had these replaced with the modified part? Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Thu Nov 26 2009 10:54am |
Charlie Crocker Member Since: 18 Nov 2009 Location: Muddy Lane Posts: 16 |
See link for fix (successful in my case)
Thu Nov 26 2009 2:09pm |
wullie Member Since: 28 Mar 2009 Location: Ayrshire Posts: 81 |
Thanks guys, do you know how much this TSB cost, I dont know what has been replaced on the car yet (bush wise) Ive not had time to look at it. Do you think this TSB would help on my RRS?
Thu Nov 26 2009 5:06pm |
It is likely it will make a difference. If it doesnt make a difference then there is likely to be a worn component which the dealer could diagnose using bulletin LTB000204v4 if you can find a dealer thats any good. The bulletin is written in order of most likely causes. First up are the front lower control arm ball joints so you should start there.
Fri Nov 27 2009 8:31am |
Can someone put a link in this post for the bulletin LTB000204v4, I have the bulletin LTB00241, I will have a go at diagnosing the problem myself, Landrover agents around me are usless , this help is much appreciated Is there a CD type manual out for the RRS yet?
Fri Nov 27 2009 1:57pm |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
Not a CD, but you can sign up to LR Global Technical Reference, which covers most things. |
Sat Nov 28 2009 10:41pm |
Interesting Leo but do you have to be a dealer to register.
Sun Nov 29 2009 6:32pm |
Micrometer Member Since: 26 Nov 2009 Location: Cambridge Posts: 39 |
No, any one can get it - you have to pay though of course!
Mon Nov 30 2009 3:21pm |
Any chance Bobby could post the bulletin LTB000204v4 if at all possible, thanks
Mon Nov 30 2009 10:27pm |
Hi folks
Sun Feb 07 2010 6:07pm |
Wullie, Does your car not have dynamic response on it? i thought all HSE's did. Trust me, i'm an Engineer! |
Thu Feb 11 2010 3:00pm |
Hi
Fri Feb 12 2010 7:54pm |
