Home > Maintenance & Modifications > Have I now got the infamous knocking |
bryanlittlefair Member Since: 03 Oct 2008 Location: Bury St Edmunds Posts: 39 |
Guys, I know and have read the posts on 'the knocking' so dont flame me straight away.. Can someone who was a confirmed case (this is sounding like swine flu) confirm my symptoms ?
Mon May 04 2009 1:50pm |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 |
I believe the "knocking" can be present on vehicles whether they have Dynamic Response or not. I had a TDv6 without DR and had a pretty severe case of the knock safter about 5,000 miles. The dealer changed all the usual suspects several times - but the knocking returned each time. Then traded her in for a TDv8 with DR. Fine for about 20,000 miles then the knocking appears. Same knocking symptoms as before. Again she has been in for all the usual suspects, plus the additional therapies like new type ball joints and removal of front resonance dampers. Worked fine for about 2 month then knocking starts coming back and now is as bad as ever. There is one stretch of road near home which really shows the knocking up to its full glory (gory). 30 - 40 mph on a poorish tarmac surface has the gremlins under the car swinging their hammers.
Mon May 04 2009 8:04pm |
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 |
I had the knocking - on my TDV6, had the ball joints and bushes changed - was all quiet for a day or two, and then back again.......get used to it!! |
Mon May 04 2009 8:12pm |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
Just had the front and rear anti-roll bushes swapped out today after complaining of the knocking noise. The drive home has been very quiet so I hope it has cured it for longer than some have had. oddly, it has sounded worse in the mornings when the car has been sat overnight and is "cold"... |
Tue May 05 2009 7:50pm |
flight Member Since: 24 Jan 2008 Location: London Posts: 186 |
Ive had mine repaired four times...
Fri May 08 2009 8:48am |
