Home > General > Tyre Wear |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
I know a lot of RRS need a wheel alignment maybe this has something to do would it? RRS TDV6 Gone but still around
Mon Jan 05 2009 2:16pm |
cyberjes Member Since: 12 Jan 2008 Location: Prague Posts: 167 |
try checking the tyre pressure.
Mon Jan 05 2009 2:25pm |
XUJG Member Since: 03 Aug 2006 Location: Left Posts: 437 |
Tyre pressure is very important so I always keep it checked.
Mon Jan 05 2009 2:53pm |
John, I went through two whole sets of tyres in 26k and had my alignment checked - all ok. A lot seems to also be dependent on tyre mfr - I had the Contis from the factory, followed by Pirellis from my local tyre emporium but both wore very heavily. That said, I couldn't say I drove it gently
Mon Jan 05 2009 2:58pm |
Mintleaf Member Since: 18 Aug 2008 Location: London Posts: 77 |
My tyres were looking worn for the miles on them, I went and had the allignment checked out and all 4 wheels were badly out...worth getting it checked. RR Sport TDV6 HSE 07MY Java Black |
Mon Jan 05 2009 3:03pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Ah but LR will tell you that this is normal tyre wear on the outer shoulders and is characteristic.........well it certainly has been on both of my RRSs.
Mon Jan 05 2009 4:32pm |
flydive Member Since: 17 May 2007 Location: South Posts: 1213 |
Yep, especially if you got Continentals, LR says is a "feature"(a bit like windows )
Mon Jan 05 2009 4:45pm |
[quote="shmoogle"]John, I went through two whole sets of tyres in 26k and had my alignment checked - all ok. A lot seems to also be dependent on tyre mfr - I had the Contis from the factory, followed by Pirellis from my local tyre emporium but both wore very heavily. That said, I couldn't say I drove it gently [/quote
Mon Jan 05 2009 10:54pm |
Thanks Mintleaf, bid you get the tyres replaced under warranty? |
Mon Jan 05 2009 10:56pm |
Not surprised to be honest - you have 2 1/2 ton of car running on 4 bits of rubber. 2005 Zambezi TDV6 - Gone but not forgotten
Mon Jan 05 2009 11:14pm |
No...i ended up buying two new rears and and thought i may as well check the allignment seeing as i shelled out £400...
Tue Jan 06 2009 1:20am |
VA - thats £50 a month on rubber then and I am only driving it 6000 mile a year.
Tue Jan 06 2009 9:47am |
John - agree it's a lot and I would have to agree the standard fitted tyres are not really up to the job as they are too soft. I've got MTR's fitted on mine and done 20,000 on them so far and would say they have another 30,000 left in them. 2005 Zambezi TDV6 - Gone but not forgotten
Tue Jan 06 2009 9:57am |
Thanks VA I will give them a look, though everyone I speak to say that hard waering tyres should not be used on a vehicle of this weight so it seems to be a rock and hard place situation. |
Tue Jan 06 2009 10:02am |
