Home > Maintenance & Modifications > Coolent Refilling
Unknown!?!?!
Coolent Refilling
hey guys. i will soon have the engine coolent for the rr sports. but i read in the instructon manual that i need anti freez and i need to mix it with the coolent liquid. but i want to make sure if the engine coolent that comes from the range rover dealer has anti freez in it or not and can you please tell me the presidures for refilling the coolent level. very important please answer soon! thanks in advance
Post #93397 Wed Mar 14 2007 4:34pm
Er... is engine coolant and antifreeze not the same thing? Or am I showing my mechanical imbecility? Confused
Post #93405 Wed Mar 14 2007 4:38pm
Unknown!?!?!
it is but in the instruction manual its diffrent i dont know why Rolling with laughter . but do i need to mix it with water or not Question
Post #93418 Wed Mar 14 2007 4:42pm
Yes you need to mix it with water. 2005 Zambezi TDV6 - Gone but not forgotten
Post #93421 Wed Mar 14 2007 4:43pm
Unknown!?!?!
but what if there is still some anti freez left is it ok to refil it or not if yes do i put the anti freez first or water and the water should be half way right?
Post #93446 Wed Mar 14 2007 4:49pm
Question May I suggest you get someone to do it for you. 2005 Zambezi TDV6 - Gone but not forgotten
Post #93448 Wed Mar 14 2007 4:51pm
Yes, dilute as per the instructions. During the winter you can leave it "raw" if you live somewhere that's stupidly cold.
Post #93450 Wed Mar 14 2007 4:51pm
Unknown!?!?!
hey guys i just spoke to the dealer and he said that you dont need to add any water and that you just fill the antifreez to the tank and that it. please reply if you dont agree
Post #93476 Wed Mar 14 2007 5:04pm
Unknown!?!?!
hey guys you might think this is a silly question but why d we add water with anti freeze
Post #93495 Wed Mar 14 2007 5:40pm
MAW
Is coolant not the mixture of ingredients - water and antifreeze... ? I guess you add water where a 100% antifreeze coolant is not required. Water is the 'coolant' to dissipate the heat but antifreeze is required in the water in some climates.
I guess if water didn't freeze and turn to ice they'd need a new name for antifreeze...
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Hope that helps.... Question
Post #93508 Wed Mar 14 2007 6:03pm
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
Confused its a parallel thread Confused some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #93660 Wed Mar 14 2007 11:59pm
Bobby
Re: Coolent Refilling
Why are you soon have the engine coolent for the rr sports?? You mean you ordered it and they are just delivering?? So all this while you're driving around on an empty radiator Question Shocked
If the coolant level is low just add water, it'll do. You only have to worry about the antifreeze etc. if the radiator has leaked badly or if you're draining the radiator. Normal top-up, just add water.
By the way, what model are you driving and what's your location? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #93662 Thu Mar 15 2007 12:10am
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
I just checked the car, because i'm off to Andorra to ski for a few days.
Found to my surprise and disapointment the coolant level in the refill compartment
to be 1\2 cm from the bottom...
This without any warnings!!
Refill with just plain water like Bobby says?
The manual indicates it needs the LR fluid mixed with water for anti freez and anti corrosion protection.
I'm leaving in the early morning! Anybody got a quick answer based on knowhow?
Cheers, SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #250276 Sun Jan 17 2010 10:15pm
Tim in Scotland
Bobby's RRS is in Malaysia, I would suggest that unless this Global Warming malarky gets a lot worse very suddenly then he doesn't actually need any antifreeze, just water. Going skiing in Andorra on the other hand (or coming to Scotland at the moment) then you need to be prepared for some seriously negative temperatures at night so I would recommend topping up with a good brand antifffffffffffffffffreeze Sky, you won't need much and you can get it from any decent autostore unless you live in Malaysia, when you might have to wait for the next shipment! You might even be able to buy top-up bottles on a motorway service area filling station. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #250280 Sun Jan 17 2010 10:37pm
SkyWalker
Thanks Tim.
So it's not needed to buy the specific LR fluid?
LR warns not to mix liquids!
Plain water will not corode the system?
What can be the cause of this spillage?
Garage floor is completely free of spots and engine compartment is clean anddry as well.
The only spot i found is a little drop around the black pressure valve. SW
Post #250287 Sun Jan 17 2010 10:56pm
