Home > Technical > Brake pad warning... |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Ditto - I had svc 3 weeks ago ish and they said then they needed doing - but poss had upto 5K left on them so I wanted to get the mileage... ahm.... out of them. Wanted around £335 from memory, I did post it that day on a service related thread... |
Wed Feb 07 2007 5:29pm |
Exactly ! |
Wed Feb 07 2007 5:45pm |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 |
On our D3 we did about a further 300 after the brake wear light came on. In that time the discs got badly scored and the dealer said they needed replaced. I actually think the brake wear indicator sensor itself might have damaged the disc, so if you hear any metallic sounds from the brakes when rolling forward, suggest you change the pads asap.... RRS TDv8 HSE Rimini
Wed Feb 07 2007 10:04pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
On my service last week they said the pads were getting near needing replacement and that I should wait for the sensors to raise the alarm. TDV6 - gone
Thu Feb 08 2007 11:11am |
I suppose a lot depends on how often you want or can be at the service dept too. I had mine done at the 1st service because it would have been inconvenient to go back a few weeks later to have them done.
Thu Feb 08 2007 11:14am |
Zipperman19 Member Since: 22 Aug 2005 Location: South Florida Posts: 85 |
Well I tend to brake kind of hard so I needed new pads at 13,000 miles. And they're just starting to squeak again at 20,100 miles. |
Thu Feb 08 2007 7:09pm |
Out of interest - when anyone has had them done - all 4 together or fronts or rears, also which go first the fronts or is it pretty even?
Fri Feb 09 2007 10:45am |
I had all 4 done, but fronts were much more worn (fairly understandably, they take the brunt of stopping 2.5t of metal)
Fri Feb 09 2007 12:01pm |
Bod Member Since: 10 Feb 2007 Location: Durham Posts: 3 |
I would try and get the pads replaced before the light comes on. Otherwise youl have to pay for a new sensor Another 20 quid or so, replace rears while your on.
Tue Feb 13 2007 9:57pm |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 |
Hi Bod surely you get the sensor wires when you buy a set of pads and why replace the rears at the same time if they dont wear at the same rate.
Tue Feb 13 2007 11:36pm |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
I replaced my front and rear pads with Greenstuff when fitting Rossini front discs. Didn't let LR anywhere near the car.., why pay £100+vat when Oily Joe around the corner does it for £30ph cash!!!
Wed Feb 14 2007 12:23am |
KevinJM Member Since: 16 Dec 2005 Location: Belgrade this week Posts: 120 |
just had mine changed at 36,000 km (22,500 miles) There was no light on the dash yet but the service said I was down to the last mm. I don't know if I should believe him but I think the mileage is about right anyway RRS TDV6 (gone)
Wed Feb 14 2007 3:39pm |
I had mine done on Monday - needed them for a work run south... down to barely more than 1mm on front with warning light flickering. It looks like the sensor contact was just about starting to score the front disks, I have the pads in the boot to examine more closely out of interest but I'd now advise if the light is on get them done without trying to get remaining mileage from them - not worth the risk of scored disks and increased ££... |
Thu Feb 15 2007 9:54am |
MikeP Member Since: 18 Dec 2006 Location: Buckinghamshire Posts: 258 |
Im just wondering guys...
Thu Feb 15 2007 4:45pm |
