Home > Technical > Suspension reset button? |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 |
hi all,
Wed Jan 31 2007 4:57am |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 |
My guess is that it is completely coincidental that the suspensions would start throwing "raising slowly" errors after you programmed/unprogrammed the remote. My suspensions used to give me the same message occasionally a few months after I purchased the car, especially if/when the weather was hot and I was going from, say, access to normal height. I never programmed the remote for suspensions control. Instead, I think the reason was a sticking solenoid valve somewhere in the system, which wouldn't open (or close, can't remember) all the way as it was supposed to. Warm weather would exacerbate the problem and there was even a TSB issued at the time about this. In any event, the message was always sporadic on my car, and it disappeared completely after the Vehicle Enhancement Program was performed several months ago. The air suspensions have been flawless since. |
Wed Jan 31 2007 7:09am |
Thanks Umberto....my guess is that you are right . It seems to have fixed itself as there was no prob this arv. Yes, my suspension has been spot on otherwise....shame I can't say the same about the rest of the car RRS TDV6 Bluetooth, VR, Roof
Wed Jan 31 2007 8:08am |
Pelyma Member Since: 29 Sep 2005 Location: Sussex Posts: 1497 |
Suspension raising slowly is not a fault, it just means it has been used a fair bit and the air resevoir is low, but if your compressor goes you do get this report as well |
Wed Jan 31 2007 5:15pm |
landroverstormer Member Since: 22 Oct 2006 Location: Somewhere close Posts: 325 |
100% def ran out of air!
Wed Jan 31 2007 10:34pm |
