| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Bonnet Catch - check it engages fully after opening! |
| Renny Joined: 01 Jun 2005 Location: Fife Posts: 21
I'd get it checked Tim. We had a similar problem with our last Tdi Discovery and ended up with a dent in the bonnet when I slammed it shut after the 6th time it blew open on the M90 heading home. Each time the safety catch held it but it was worrying.
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 7170
Autocar have had the same problem - but at much higher speed than I was doing |
| MDP Joined: 15 Jun 2005 Location: Back in an AUDI Posts: 8389
Tim perhaps on your next trip to B&Q you may consider picking up a roll of Duck Tape...... ..affix it to your bonnet....... call into your dealer,looking extremely worried & bearing this weeks copy of Autocar ........this should do the trick. |
| Biggles Joined: 26 May 2005 Location: Preston, Posts: 916
Have you spoke to the dealer over this, if so what are they doing about the problem. |
| Andrew Joined: 16 Jun 2005 Location: Cheltenham Posts: 48
I have found the only way to close the bonnet successfully is to cringe as you slam it shut from about 6 to 8 inches high!! |
| Simon Joined: 13 Jun 2005 Posts: 44
Same problem when I took delivery.
My old P38A developed a dint in the bonnet using the push gently method, some things never change |
| Robbi Joined: 14 Jun 2005 Location: Channel Islands, Guernsey Posts: 119
When I closed the bonnet on my dealer's demo I thought I had dented it after pressing down on it! It's quite soft.....aluminium I believe? And they say 4x4's are pedestrian unfriendly. |
It happened again today despite slamming the bonnet pretty hard so drove along to the dealer and they adjusted the nearside catch while I waited, and then told me that nearly every car delivered by the dealer has been back for the same fix. I think it may be a dealer mechanics "fix" rather than an official technical note "fix" from Solihull. So if you have had this problem too give your dealer a visit and ask them about it. |
Tim, I quized my dealer today over the bonnet catch issues & unfortunately he or the dealership hav'nt come accross any such failings as yet, but looking at the quantity they are shifting I'm sure it will only be a matter of time because it seems as though it is a common problem.I have made him aware of other peoples experiences re this & other points raised on this site. |
| gribnau Joined: 17 Jun 2005 Location: Santa Clara, Bay Area, CA Posts: 86
My service manager said to let the bonnet fall in place from approx 15" height and put some force behind it - he mentioned that for YEARS landrover bonnet's need to be closed with force but not push it down but let it fall in place with force - i hope this makes sense.... |
