Home > General > FBH screw up |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 422 |
Was having an HVAC issue on my personal car (2011 L320 3.0 TDV6) so using JLR-SDD I configured the HVAC module which did an update, all good and well. Decided to update the Aux Heater while in there and it’s all gone sideways. It refuses to update and now the module is not doing anything. Any suggestions? Tried taking the battery terminals off and touching them together. The fault is U3000-49 Aux Heater module.
Wed Mar 13 2024 9:42am |
A baffling update; I had to walk away from it since I needed to earn my keep at the shop. When I parked the car the timed heat button was blacked out, as it had been since the whole module fiasco started this morning. However, when leaving work it was back to normal and allowed me to set the timers. So I did and will wait till the morning to see if it’s back in the game or still having issues.
Wed Mar 13 2024 8:01pm |
No luck. Not sure what to look at or try next. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Mar 14 2024 9:44am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
Have you tried this? only a suggestion.
Thu Mar 14 2024 10:03am |
Will try that later today after the car cools down from the drive to work. Just odd I can’t even get it to program.
Fri Mar 15 2024 7:17am |
