Home > Technical > 2011 L320 rear propshaft |
Pitcher Member Since: 07 Feb 2022 Location: Birmingham ish Posts: 20 |
Hi, I'm getting a bit of a bit of a metal knocking as driving, it comes and goes, but starting to come more often, defiantly centre of the car, behind front seat area.
Mon Mar 04 2024 7:09pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 304 |
Save your self a world of pain.......change the whole prop |
Mon Mar 04 2024 7:38pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
Recalling having read some previous post on others experience with replacing the rear prop, if you do replace the complete prop make sure you buy a good quality one like GKN or something, as it would appear the cheap one's are just that, cheap, nasty crap which won't last or not balanced.
Mon Mar 04 2024 9:02pm |
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 78 |
I had mine replaced last autumn after 103k. I thought it might just be the centre joint bush, but was glad I accepted my indie's advice to have the whole shaft replaced. The photo shows the old one was completely shot. It's effectively a consumable component on the L320 and L319
Tue Mar 05 2024 3:54pm |
Spent a couple of hours underneath this morning, it's off and did panic it may not come off due to some of the Star bolts looking rounded off in places, so guess its not the first time it's been off?
Sat Mar 09 2024 1:54pm |
Sat Mar 09 2024 10:35pm |
Thankyou, new propshaft and bolts have arrived, just about to put it back together |
Sat Mar 16 2024 10:38am |
