Home > Technical > Tdv8 smoking when cold |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8856 |
The crankcase breather system vents gases back in to the inlet of the driver's side turbo (RHD), so if the separator isn't perfect you could get some getting through.
Wed Feb 07 2024 11:40pm |
Jellis39 Member Since: 21 Apr 2019 Location: Melton Mowbray Posts: 58 |
Thank you for the reply.I set pre heat this morning and didn’t notice any smoke at all. Gave it the beans and it did nothing! Same when I left work, nothing. It’s very odd, but I do wonder if the car sits a couple of days the oil drains down the breather and sits in the right turbo intake and then gets blown into engine. I’d expect turbo seals would cause smoke all the time, especially at idle and then when booted would smoke. I’ll try it again tomorrow but hoping it’s the breather. I’d like to know how the breather works, as in should it open at a certain pressure, in like to understand how things work! |
Thu Feb 08 2024 7:45pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4858 |
https://drive.google.com/file/d/11rVrgEIFj...sp=sharing
Thu Feb 08 2024 10:08pm |
