Home > General (L494) > Range rover cover up for the steering rack bolt failures |
jcchief Member Since: 28 Jan 2024 Location: manchester Posts: 9 |
Range Rover chooses profits over safety by not recalling UK cars after using incorrect bolts in the steering rack.
Tue Feb 06 2024 6:48am |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 576 |
How can you check if you own a model fitted with the wrong bolts ? |
Tue Feb 06 2024 11:44am |
If You can get access put a magnet on the bolts if it sticks they are steel.
Tue Feb 06 2024 11:54am |
Wed Feb 07 2024 7:14am |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 182 |
uRGHHHHHHH!
Wed Feb 07 2024 10:52am |
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 112 |
Could the bolts be exchanged at a regular service easily? or is it a huge job?
Wed Feb 07 2024 11:40am |
Yes would like to know the same, if its a case of accessing the steering rack and swapping the bolts out? |
Wed Feb 07 2024 11:55am |
access makes it a bit difficult but a lot of garages wont touch them because if they shear the bolts while trying to remove them it escalates the cost and time to fix.
Wed Feb 07 2024 11:56am |
