Home > Technical > Drop bar links rear |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 120 |
Nightmare. I guess, supplying the parts outlet with a chassis number is your best bet. |
Sat Jan 27 2024 11:30pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Yes, they are different...
Sun Jan 28 2024 2:02pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 332 |
I think you missed the point which is the two numbers seem to be for identical products but one is twice the price of the other ..... Always listen to old people or when they die you will live on in ignorance.
Sun Jan 28 2024 3:46pm |
They have different part numbers because they are different parts.
Sun Jan 28 2024 4:09pm |
Both the specs I have say 126mm
Sun Jan 28 2024 5:56pm |
Where are you getting your numbers from which suggest ACE and non-ACE are the same? And are you getting your measurements from a retailer or manufacturer?
Sun Jan 28 2024 6:32pm |
Wow thanks for all the effort
Sun Jan 28 2024 8:55pm |
No problem Kev
Sun Jan 28 2024 8:58pm |
Checked on the friends and mine an they are both ESC and are 132mm between the ends of the bolts.
Mon Jan 29 2024 11:12am |
As far as I can tell.........
Mon Jan 29 2024 2:04pm |
