frostmotorsport
is it because it just doesn't open on the tailgate switch, or is it jammed shut in some way? I just fixed mine that was intermittently not opening on the tailgate switch - but I have my 3rd remote button programmed for the tailgate, so not a big issue and it happily pops on the remote.
When I took the switch unit out, it was full of gunge and a good clean out, scrape all the crap out, lubricate the "hinges" for the unit (the microswitch itself is fine) and re-assemble and she is working sweet.
it's worth taking the garnish cover off anyway as that whole thing is a trap for dirt and rust, and I removed the metal frame, wire-wheeled it, rust-killed it, painted it and reinstalled after cleaning a lot of dirt out of that general area.
If the tailgate itself is stuck (i.e. you can hear the latch pop but it doesn't release) then you have a bigger issue, and may need to start disassembling the tailgate from the inside out. Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Sun Feb 18 2024 6:39am |
