Home > My Range Rover Sport > Another 1st time RRS owner |
MHSPORT08 Member Since: 13 Nov 2023 Location: South East Posts: 37 |
Thanks for the Can Bus data info, seems a bit strange but I’ll try and get a more powerful reader on the car to see if anything can be found |
Wed Nov 29 2023 10:25am |
A few updates.
Fri Dec 08 2023 10:35am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8867 |
Might be worth changing the EAS relay - if the pump was replaced but the relay left, it has been known to throw an error (no idea why). 2012 SDV6 - it's missing a couple of cylinders
Fri Dec 08 2023 5:14pm |
Good point there.
Sat Dec 09 2023 4:53pm |
I ordered a compressor relay and its arrived but some more things have sprung up since.
Tue Dec 12 2023 7:14pm |
A4j1s0 Member Since: 11 May 2022 Location: Gloucestershire Posts: 27 |
I had the same fault and it was a blocked filter on the exhaust side.
Tue Dec 12 2023 7:22pm |
Great thanks for that tip.
Tue Dec 12 2023 7:38pm |
The fresh air feed comes from the left hand side in the load compartment and has a filter on the top.
Tue Dec 12 2023 8:04pm |
Thanks for those tips on the air pump feeds.
Wed Jan 10 2024 11:12am |
Ok I think we are there.
Mon Jan 15 2024 11:58pm |
Small update, had the suspension height calibrated
Sat Feb 03 2024 9:43am |
Done about 2k now and suspension seems good but it went into limp mode the other day on the motor way.
Tue Feb 27 2024 2:56pm |
