Home > Faults & Fixes > Water pump.....fell off! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8863 |
10Nm for the pump bolts, 25Nm for the pulley bolts. According to the workshop manual.
Thu Jun 08 2023 4:46pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4811 |
Can happen after the cam belt has been done. And someone has loosened the wrong bolts and forgot to tighten |
Thu Jun 08 2023 6:20pm |
At least it was the water pump and an oil pump failing. 2012 SDV6 - it's missing a couple of cylinders
Thu Jun 08 2023 6:47pm |
cardicowboy Member Since: 13 Jun 2021 Location: Mostyn Posts: 5 |
Thank you very much for your assistance.
Fri Jun 16 2023 4:42pm |
ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 20 |
Apologies to reopen an old topic, but mine has just done the same thing - did the timing belt recently and am sure i never touched any of the water pump bolts, but two seem to have sheered and the third bent open.
Fri Dec 01 2023 12:11pm |
Luckily for me one just unscrewed, but the other was quite tight, but used a small chisel to tap it round and round. It came eventually.
Fri Dec 01 2023 2:00pm |
Many thanks - have just bought everything i can find on amazon to get here tomorrow. Will likely try easy outs if i can manage to drill a straight hole.
Fri Dec 01 2023 2:56pm |
Just to round out this saga of mine....no snapped stud in the top hole so am now thinking i did accidentally remove it when undoing the cam belt cover....so blaming stupid rookie error.
Wed Dec 06 2023 10:09am |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 226 |
Just a tip, if possible after removing a stud, always run a tap down the hole to refresh the threads and as a final check when fitting new bolts, make sure the hole is deep enough to prevent the fastener bottoming out and giving the illusion of tightness, easy to do if the fastening is in a awkward spot.
Fri Dec 08 2023 11:04am |
