![]() | Home > Technical > Which compressor do I have fitted |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5069 ![]() ![]() ![]() |
The problem is, if it has been changed before it could be either Hitachi or AMK, easiest way is drop the plastic cover and have a look, they have different mounting bracket's so easy to tell, if still original proably Hitachi.
If you see RVC500010 on the lower cover it is most likely Hitachi. The Hitachi covers won’t fit an AMK unless it’s some knock off unit. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
I think you might find RVC500020 is the upper half, the number on the lower part you can see is RVC500010
Doh! Fixed it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
AcePratt Member Since: 23 Oct 2023 Location: Leicester Posts: 16 ![]() ![]() ![]() |
Thanks all,
