Home > Technical > suspension fault |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4804 |
Ensure park brake off when u do it. Ideally out
Wed Nov 29 2023 12:49pm |
mark8815 Member Since: 12 Nov 2023 Location: West Yorkshire Posts: 22 |
Great thankyou. Didnt realise the park brake needed to be off, on mine it works both on and off. Thanks again |
Wed Nov 29 2023 1:03pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
It will work with the park brake selected, but if you watch the wheels when you lower to access height, you will see that there is a slight change in wheelbase - the front wheels turn ever so slightly if the EPB is applied. That rotation is then applying torque to any part of the drivetrain that is restrained. No idea if that includes the gearbox in park but knocking it in to access height as you slow to a stop means that everything is free to move as it settles.
Wed Nov 29 2023 4:11pm |
