Home > Technical > Suspension Relay |
skullbyka Member Since: 10 Mar 2023 Location: London Posts: 12 |
Can anyone tell me the reason why replacement Compressors ( in my case the Hitachi) for my RRS 2005 Supercharged are often advertised as coming with a Relay ? if the existing relay is fully functioning is this new relay still necessary or is it merely a "stealership" tax ? I am the darkness before the storm |
Wed Nov 15 2023 3:12pm |
Thanks Andy - that makes sense 👌 I am the darkness before the storm |
Wed Nov 15 2023 10:44pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 122 |
I replace my compressor relay once every 12-18 months. Increased contact resistance reduces current flow causing the pump to work over a longer period of time. |
Tue Nov 28 2023 7:23am |
Thanks erickwan - I think I will follow your lead on that and replace mine regularly.
Wed Nov 29 2023 3:17pm |
I cannot be sure if this results in pump longevity, but the original pump that came with the new car lasted 250,000 kms. It died when the crank bearing disintegrated.
Thu Nov 30 2023 4:40pm |
