Home > General > Warped front discs? |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
Possible, and more than likely, however dodgy wheel bearings will give the same effect, as can knackered suspension joints, so whilst you might be right, you could also be wrong.
Sat Nov 11 2023 2:07pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 426 |
Could be the rear rotors as well. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sat Nov 11 2023 3:18pm |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 239 |
All the discs looked like they had seen better days. The steering did feel a little remote and pedestrian too.
Sat Nov 11 2023 3:22pm |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 195 |
Could just be poor transfer of material on to the rotors - ie not bedded in properly and now have ‘lumps’ of pad material on them. Might be worth cleaning them before jumping to replacement unless they are knack*rd |
Sat Nov 11 2023 3:53pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8853 |
An incompletely tightened wheel can give some nasty vibrations when loaded even if it's ok at other times. 2012 SDV6 - it's missing a couple of cylinders
Sun Nov 12 2023 10:02am |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 192 |
My MY2012 eats front brakes. Every 2 years they need to be replaced and I still to this day have them done at the dealer under warranty.
Tue Nov 14 2023 6:40pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 389 |
The runout could be any number of problems. You will need to fix them first to get an idea of where to look.
Wed Nov 15 2023 10:22pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4857 |
13 years for a set of pads and disks is OK, but as you never say what milage you have done, if it's only 25k it ain't good is it.
Wed Nov 15 2023 11:26pm |
The car has just over 75,000Km on the clock and spends about 1-1.5 h per day being driven (stop start driving). |
Wed Nov 15 2023 11:50pm |
