Home > Faults & Fixes > 2006 tailgate fix.
Joe Hankey
England 2006 Range Rover Sport TDV6 HSE Bonatti Grey
2006 tailgate fix.
Good afternoon. I have a 2006 rangerover sport. 2.7. I have a fault with it not opening. It's saying on the dash tailgate open but it is still locked and will not open. As anyone who can help me with this please.
Post #636893 Sat Oct 28 2023 1:24pm
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
I've had this too!
The problem is due to the sensor in the lower tailgate lock module not sending the "locked" signal to the system, which then thinks it's still open so can't be unlocked! In my case it also prevented me locking the car doors.
The fix will be a replacement lower tailgate lock. It's the same as on the Ford Galaxy for a great deal less than the LR price (Ford part: 3M51R442A66AR)
I was able to release mine by repeated thumping on the tailgate over the lock - good luck with that!
PowerfulUK have a video of how to open both the top and bottom tailgates so that you can remove the trim panel. Open the top tailgate and then trip the latch with the shaft of a screwdriver to fool it into thinking its closed.
You'll need to take out the sub-woofer to extract the lock, so mark its orientation first because it's not as symmetrical as it looks.
Apart from that it's a straightforward job.
Best of luck
Post #637172 Thu Nov 09 2023 4:07pm
Joe Hankey
Lock
Thankyou very much have done as you said. It's all ok now thankyou very much. Thumbs Up
Post #637456 Mon Nov 20 2023 1:04pm
