Home > Faults & Fixes > Inner door lock handle restricted movement |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 422 |
Door latch modules are failing. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sat Nov 04 2023 2:22pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 527 |
As above….
Tue Nov 07 2023 11:10pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Thanks to you both for replying, most helpful. 2006 2.7 TDV6 HSE in Cairns Blue. |
Wed Nov 08 2023 6:06pm |
The locking module is effectively the door lock mechanism but where it gets complicated is that the mechanism is driven by two scalextrix size electric motors which start to fail over time.. the end up not strong enough to close the levers.. hence your problem…
Wed Nov 08 2023 6:22pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 334 |
Just looked at a video on removing the door cards. You are saying its the lock unit thats failing rather than the electronic module....is that right?
Thu Nov 09 2023 10:58am |
Have just pm’d you..
Thu Nov 09 2023 11:18am |
Many thanks to both who replied ...job for the warm weather ..I sit in the front !! Always listen to old people or when they die you will live on in ignorance.
Thu Nov 09 2023 11:22am |
Both of my rear latches need to be replaced as well. The hardest part is probably getting the window regulator out of the door. After that it’s not too bad. Connecting the cables is a fun exercise in dexterity. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Nov 09 2023 3:37pm |
having had a lot of experience with Jaguar door locks eventually replacing the whole thing with a new Chinese system for £20 I just raise this question.
Thu Nov 09 2023 4:02pm |
Think more as the lock lever is just an indicator. The mechanism is the latch. If the mechanism isn’t working correctly then the indicator won’t show correctly. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Nov 09 2023 6:25pm |
