Home > Faults & Fixes > Clunk when pulling lever out of P |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 747 |
I had the gear lever go stiff on me which is a common problem when the gear lever pivot coming out of the gearbox becomes covered in crud. Some replace it with a new one, but I just cleaned it up and gave it a bit of lubricant and it's been fine since. Could this be your problem?
Thu Oct 05 2023 11:02pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Wow thanks for your reply. I've had a thought and I'll feel this morning. When I raise the car then try to deselect P and see how it feels. If clinky you might have nailed it. 2006 2.7 TDV6 HSE in Cairns Blue. |
Fri Oct 06 2023 6:34am |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
Try putting it in access mode with the gearbox in N and the handbrake off.
Fri Oct 06 2023 9:36am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I often use Access mode and have got into the habit of selecting this before I come to a complete stop so that the suspension has time to adjust. Then into N and put the handbrake on before selecting P just to reduce strain on the little pin in the gearbox that locates when you select P. Don't want 2.5 tons all pressing on that little pin especially if parked on a hill. Robin
Thu Oct 12 2023 12:01pm |
It has made a difference as you all say above. Stop, into N then lower, handbrake on and into P.
Thu Oct 12 2023 5:30pm |
Great so hear Steve. Now just go one better and keep it rolling as you select Access mode and keep it rolling until Access mode is done. Then handbrake on etc.
Thu Oct 12 2023 5:50pm |
