Home > Maintenance & Modifications > Aftermarket Air Intake for 2010 SC?
BurgerJoe
United States 2010 Range Rover Sport Supercharged Java Black
Hey yall I just recently got a 2010 RRS SC and have no previous modding experience. I want to make the supercharger whine louder and a hair increase in HP with the addition of an aftermarket AI. I dont know if adding one will just make the car slower and/or if it will need a tune after the installation.
This is the AI i am planning on buying.
https://www.ebay.com/itm/354014212536?hash...SwhJdhkUul
There is a more expensive one but I dont have the money for that right now. Any help is appreciated.
Post #636435 Fri Oct 06 2023 7:13pm
It’s got 2 air intakes. That’s plenty
You increase the chances of drawing in hot air, which will reduce performance
Post #636436 Fri Oct 06 2023 7:44pm
BurgerJoe
So having an open air intake will make it worse? Because I was looking for an increase in whine. If thats the case do you know anything else that can help with the SC whine to make it louder? I removed the plastic hood cover but thats pretty much it.
Thank you for responding, its the first helpful one ive gotten on any forum
Post #636437 Fri Oct 06 2023 7:51pm
Well you could remove the bonnet sound deadening (black frabric)
If it’s anything like the jaguar it’s based on, The supercharger blades are coated in something to make them quiet!
Post #636438 Fri Oct 06 2023 7:58pm
BurgerJoe
Yea if im right its the 5.0 L AJ-V8 from that was built in combo with Jag and LR. That sucks. I saw a couple cables underneath the bonnet. Will the heat from the engine be a cause of worry to the cables? meaning is there a possibility that the heat will melt the cables under the hood?
Post #636439 Fri Oct 06 2023 8:02pm
No. Should be fine
Washer jet cables I guess
Post #636440 Fri Oct 06 2023 8:11pm
