Home > Technical > Range rover sport l494 sdv6 no vacuum on bank 1 |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4345 |
The 2nd MAF will have no reading, as the secondary turbo was not spinning. Completely normal
Thu Sep 21 2023 12:44pm |
needle Member Since: 13 Nov 2014 Location: aberdeen Posts: 27 |
even when out for a run ? was redlining at times but still nothing from maf 1 during live data |
Thu Sep 21 2023 12:55pm |
What diag are you using?
Thu Sep 21 2023 4:01pm |
Autel 808 |
Thu Sep 21 2023 4:04pm |
If its not a boost leak, then better diag gear is required |
Thu Sep 21 2023 7:13pm |
looks like its the turbo shut off valve , tried exercising it with the autel and it opened slightly then gave me some vacuum then sh*t itself again , looks like its seized shut, freed it up and seems to be ok now |
Thu Sep 21 2023 7:22pm |
