Home > Technical > Ctek Charger Connection |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4801 |
I think you need to connect it to the Jump start points. Be a red cover somewhere.
Thu Aug 31 2023 9:55pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4858 |
I connected the Neg/Live to the battery lead under the engine bay fuse box cover and the Pos/Earth to the earth stud located at same end of fuse box on the wing valance, been working fine for 7/8 years.
Thu Aug 31 2023 10:07pm |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 136 |
Eh up both
Thu Aug 31 2023 10:18pm |
Not the best picture, but you will see a stud in the area marked, never actually noticed any jump lead points under the bonnet of a L320.
Thu Aug 31 2023 10:26pm |
Eh up
Fri Sep 01 2023 8:50pm |
In your top picture the positive is fine there, it's the same lead just at the battery terminal as opposed to the fuse box one, the negative connection is the wrong side of the BMS module.
Fri Sep 01 2023 10:58pm |
Eh up Col
Sat Sep 02 2023 8:28am |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 426 |
You definitely do not want to connect direct to the negative terminal with BMS. The BMS monitors the battery charge level. If you connect to the negative terminal direct it won’t see the battery charge increase and can potentially overcharge the battery (BMS thinks it’s at 70%, it’s actually at 95% and it goes full tilt trying to charge it). Same reason you don’t want to connect any accessories direct to the negative terminal, it can drain the battery and BMS thinks it’s charged.
Sat Sep 02 2023 6:58pm |
Ehup NoExpert
Sat Sep 02 2023 7:42pm |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 193 |
Sorry to reopen this but, I just wanted to check something.
Fri Jan 19 2024 7:19am |
With a Ctek charger Yes, you leave it connected when the vehicle not being used and it keep the battery topped up.
Fri Jan 19 2024 7:31am |
Hi Col,
Fri Jan 19 2024 8:17am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
If you have 13pin or twin 7 towing electrics it can be done through there with a ctek adaptor Visitor from fullfatrr.com
Fri Jan 19 2024 9:06am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8856 |
As Rob says, charging through the towing electrics is another way - you just plug the CTek in to the towing point and off it goes doing its thing. No need to worry about where you are in relation to the BMS, etc., and no need to open the bonnet, etc.. That's the way I do it if I need to charge up (which isn't very often as mine gets used for decent length journeys most of the time).
Fri Jan 19 2024 2:10pm |
