Home > Faults & Fixes > TDV8 turbo failure (3,6)- which side is common to fail?
Boater
Denmark 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hi there,
I have a 2007 RRS 3,6 - TDV8, left turbo has failed. The car only has 97.000 km on the clock.
I am searching for statistics - is it most common to have turbo failure on the left side, or right side?
If it is most common on the LH side, why is that?
Would i need to replace both, or just the one on the left?
Post #635409 Tue Aug 29 2023 4:11pm
Hightimo
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
I have done a couple of these now and given the age and mileage I would replace both , especially if oil has gone into the intercooler, you need to clean everything you can , best you can if that’s the case . Last one I did it had failed and filled the exhaust collector box up with oil , so even after draining there will be smoke for a bit while it all burns off .
Post #635466 Thu Aug 31 2023 6:04am
