Home > Faults & Fixes > Ace pipes replaced (pics) now juddering
Tom Davison
Yes it looks a very smart job, and presumably opens up the pipe replacement to a more DIY solution rather than body off job?
Post #635172 Sat Aug 19 2023 7:48pm
Brit Plumber
Yes, definitely a DIY mechanic job and much easier and cheaper than lifting the body. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #635174 Sat Aug 19 2023 7:57pm
Pistnbroke
While we have so many interested people on the thread have i not heard of removing the pump ,fitting a shorter belt to disable the system. What about warning lights.
My neighbour has RRS and the ace pipes are so rusty I dare not touch them ..just coated them with marine epoxy then waxoil and spiral wrap and left him to it ... Always listen to old people or when they die you will live on in ignorance.
Post #635176 Sun Aug 20 2023 7:46am
Disco_Mikey
ARC pipes are not body off to replace Thumbs Up
I've removed the ARC system on plenty of 2.7s, a few 3.0s and sussed the 3.6, but never done it
Post #635177 Sun Aug 20 2023 8:06am
Pistnbroke
Quote
" Removed the ACE system "
Do you mean removed and replaced or removed totally . More details if the latter appreciated. Always listen to old people or when they die you will live on in ignorance.
Post #635178 Sun Aug 20 2023 8:12am
Brit Plumber
Is that a “not a body off, but still need to lift?” There’s no way I could get my pipes in on the 5.0 without bending the pipes, lifting the body a few inches or cutting them, the bends in the pipes exceeded the space available. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #635184 Sun Aug 20 2023 6:38pm
Cchewy
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
Brit Plumber wrote:
I have no idea about your issue but when my ACE pipes needed changing I didn’t lift the body, I bought some 3500bar couplers from the local agriculture machinery supplier and cut the pipes and fitted them that way. Some have managed to fit them without even cutting them but I didn’t have enough room.
It cost £200 for the pipes and £12 for couplers I think it was.
Hi All,
Does anyone know the pipe size of the ARC pipes. Looking to pick up some compression joiners and should imagine a 10mm coupler will do but thought as you have done this job before you could possibly know for sure the size…. Thanks in advance.
Post #641326 Sat Apr 20 2024 4:37pm
Brit Plumber
It’s been quite a while but I think it was 10mm. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #641329 Sat Apr 20 2024 5:27pm
Cchewy
Thanks for getting back to me. Ended up popping into screwfix to buy a micrometer and it is as near as damn it.
Post #641330 Sat Apr 20 2024 5:34pm
