Home > General > Front sump guard |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4863 |
The two 6 mm screws at the front are just screwed into spring clip/nuts, If they are just rotating I would imagine someone has bodged the wrong screws in or over tightened them and broken the clip in two halves so it just rotates.
Sat Aug 05 2023 10:44pm |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 136 |
Sun Aug 06 2023 8:55am |
If I remember right there are just welded captive nuts that retain the rear bolts, fitting a new front guard will automatical replace the nuts as they are welded to that. If the heads are missing on the rear bolts if you can get the front two out the the guard will basicaly drop out.
Sun Aug 06 2023 9:07am |
Sun Aug 06 2023 9:18am |
Belive it or not but the 10mm bolts are actualy torqued up to 62 Nm I also seem to recall they are serrated flange headed bolts as well.
Sun Aug 06 2023 9:31am |
62Nm
Sun Aug 06 2023 9:37am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4801 |
The rears also bolt thru the large engine cover.
Sun Aug 06 2023 10:16am |
Discusses bolts fittings for large engine tray
Sun Aug 06 2023 10:18am |
Andyk
Sun Aug 06 2023 10:42am |
Can you not just grind the heads off the front bolts an get some new ones they are only 6 x 13mm.o.e. part number KYG50038O the10 x 20mm FS110206 & 10 x 25mm KYG500500
Sun Aug 06 2023 11:27am |
Eh up all,
Tue Aug 22 2023 9:28pm |
One on the left I think.
Wed Aug 23 2023 8:55am |
The spring clips have proably snapped in half leaving the top half just free to rotate and not undo, why not just cut or grind the head off the bolts the broken bits will then just fall out.
Wed Aug 23 2023 9:24am |
Eh up Col / Andy K
Wed Aug 23 2023 10:13am |
