Home > General > Replacing ECM LR12730 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4801 |
Engine module. They contain the imboliser code usually so a replacement won’t just work unless
Thu Aug 03 2023 6:22pm |
DirtyApe4x4 Member Since: 06 Jun 2020 Location: Dayton, Ohio Posts: 23 |
Thanks - it will be reprogrammed, I didn’t know if anyone has had issues trying to rewrite with new VIN… 2011 Range Rover Sport GT Limited Edition/Santorini Black 5.0 Liter
Thu Aug 03 2023 11:42pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4860 |
Only a question, is car your car a S/C or N/A? only apart from a digit (0) being missing from part number you quoted that is for the N/A.
Thu Aug 03 2023 11:49pm |
It’s not the supercharged…USA regular old HSE petrol…part number came from dealer. 2011 Range Rover Sport GT Limited Edition/Santorini Black 5.0 Liter
Fri Aug 04 2023 12:17am |
I think the part no. should be LR012730 unless for some reason they drop the "0" in the States.
Fri Aug 04 2023 12:34am |
You are correct! Should have the zero…got lost in translation…thanks for noticing! 2011 Range Rover Sport GT Limited Edition/Santorini Black 5.0 Liter
Fri Aug 04 2023 1:01am |
Sat Aug 05 2023 2:07pm |
###update###
Thu Aug 10 2023 10:50pm |
