Home > General > No crank no start, lights flashes on the dashboard |
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 |
is your vehicle right or left hand drive? if rh, then is suspect you have water ingress hitting the fuse box. also remove battery & check ecu for water damage. |
Tue Aug 01 2023 10:53pm |
Willie T Member Since: 27 Jul 2023 Location: West Africa Posts: 7 |
Thanks for your reply.
Wed Aug 02 2023 1:36pm |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
1. Water ingress around the base of the right-hand (passenger) A-pillar.
Wed Aug 02 2023 2:01pm |
Wed Aug 02 2023 3:39pm |
Here's an example: https://www.facebook.com/JASLandRoversLtd/...55/?type=3 Regards etc.,
Wed Aug 02 2023 4:39pm |
Thanks for your help.
Wed Aug 02 2023 6:15pm |
These are the lights flashing on the dashboard
Wed Aug 02 2023 6:22pm |
An E stands for gearbox error.
Wed Aug 02 2023 9:29pm |
Thank you so much for your help.
Thu Aug 03 2023 7:32am |
