Home > Faults & Fixes > Battery ?
Motorman
United Kingdom 2007 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Battery ?
This is a weird one
Out of the blue the battery is nearly dead and when you try to start the instrument cluster flashes on and off
If I stick the battery charger on for half an hour miraculously its got a full charge and starts with plenty of life in it,
Ive bought a battery to replace but just thought I would post the problem if someone else has had this and its more of a challenge than the battery
Thanks
Post #634713 Tue Aug 01 2023 10:02am
gogsy1956
I would be looking at your alternator,, check your charging voltage,, and if you have a clamp meter, the current. Wouldn't cost anything to check the battery terminals either making sure they're tight. I had a similar issue thinking it was the battery I changed it,, but the battery died for no reason one night. Put it down to short runs in winter but noticed by accident that on a 20 milers the battery voltage dropped to 13.5V for a short while. Thought no more of it then the alternator failed a couple of weeks later. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #634726 Tue Aug 01 2023 7:37pm
Initially I would have thought the battery has a couple or so dead cells that won't hold charge, what age is the battery?
Post #634736 Wed Aug 02 2023 5:11am
Motorman
The battery is a good age Ive got another one coming just hoping its not something draining the battery
Post #634738 Wed Aug 02 2023 6:29am
gogsy1956
Ahh,, I assumed you had fitted a new battery,, but if your still using an old one I completely agree with Col,, definitely sounds like the battery is only holding a small amount of its capacity,,,,, but check your charging rates as a matter of course. 2010 RRS, TDV8
22" overfinch
Post #634741 Wed Aug 02 2023 9:27am
Motorman
Hi
Thanks for feedback
Ive got an intelligent battery charger
It has a repair facility so did that re charged then it seams ok then a couple of hours later dies
Im 95% on the battery being duff but thought I would throw the question out there in case anyone had experienced battery drain on their cars
Thanks for your help
Post #634742 Wed Aug 02 2023 9:59am
It does sound like a dead cell in the battery. The battery charger can only do so much - once the cell is dead, it's dead. You get an apparent ok reading after charging because the plates have an excess charge on them initially so it reads good. Once that surface charge dissipates (over several hours), you get the true reading.
When you put in your new battery, it would be worth checking voltages to see if you have any losses when it's sat doing nothing, also check engine-off and idling voltages to see that the alternator is ok. If you get low voltages when idling then suspect the alternator is tired. 2012 SDV6 - it's missing a couple of cylinders
Post #634743 Wed Aug 02 2023 10:33am
Motorman
Hi
Thanks or info
The alternator is ok its kicking out 14.2v back to battery when engine running
so looks like on the money with new battery replacement
Many thanks for help with this
Post #634745 Wed Aug 02 2023 10:36am
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #634758 Wed Aug 02 2023 5:46pm
