Home > General > ARB Replacement |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
ARC?
Sun Jul 16 2023 6:46pm |
Josh95 Member Since: 08 Dec 2021 Location: Belfast Posts: 49 |
Anti roll bar?
Sun Jul 16 2023 7:29pm |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 39 |
The body needs to be lifted a small amount from the chassis at the rear to allow access to remove\replace the bar. Some work but no where near as much work as a full body off.
Mon Jul 17 2023 12:25am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8856 |
If they do lift the body off, consider the fixed brake lines that run along the chassis. They're not expensive but basically need the body lifting to do them. Also, have the crossover pipe on the rear of the engine checked for corrosion. That's an expensive item (£400, I think) but is a body off job (or at least an awful lot easier and quicker with the body off). Rather depends on how long you intend to keep the vehicle, really. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Jul 17 2023 8:59am |
Does anyone know if this would be an MOT fail? |
Wed Aug 09 2023 1:50pm |
