Home > Maintenance & Modifications > RRS 2010 failed MOT On
AIJ 615
Mot failed today on:
Suspension arm ball joint dust cover no longer prevents the ingress of dirt Offside
How much to supply and replace this you think guys ?
Post #633886 Thu Jun 22 2023 9:36pm
The ball joints aren't expensive: £20-30. The cost is going to be getting the old one out and pressing the new one in. 2012 SDV6 - it's missing a couple of cylinders
Post #633890 Fri Jun 23 2023 9:55am
AIJ 615
How much labour you think ? (Hours)
Post #633891 Fri Jun 23 2023 10:02am
No idea. If it all goes well, maybe a couple. If they have to fight to get it apart/back together then could be all day. 2012 SDV6 - it's missing a couple of cylinders
Post #633895 Fri Jun 23 2023 2:47pm
AIJ 615
Hi all, so I’ve now been told when I dropped the RRS into ATS for mot repair that it’s a complete new suspension arm as they don’t just replace the dust cover ?
Like hmmmm, really ?
Al
Post #633942 Mon Jun 26 2023 3:02pm
If the dust cover is ripped and has allowed grit in to the bearing then just replacing the cover isn't much use. Replacing the joint can be done if you can remove/replace the ball joint in situ. If you can't, then you're looking at a new arm anyway as the bolts usually seize and require cutting off.
I'm not sure I'd want ATS working on an RRS anyway, frankly. An LR indie would be a better option if you have one nearby. 2012 SDV6 - it's missing a couple of cylinders
Post #633944 Mon Jun 26 2023 5:29pm
Stevepd
As stated above. I wouldn't want a garage that serves "everything" on such a complicated vehicle. There must be a decent indie near?. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #633954 Tue Jun 27 2023 6:47am
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
A decent garage will have the tooling to press the joint out in situ, if your handy you can hire from HSS a hand held hydraulic press kit, a new Ball joint, (oe for 60 ish I think) and a few hours work.
Check your bottom arm bushes too - if getting tired and you plan to keep her for a while then go for new bottom arms to save having to go though it all again next year.
Post #633959 Tue Jun 27 2023 8:47am
