Home > Faults & Fixes > 2015 rrs ticking |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Hello and welcome. A bit more info is required for others to contribute. What engine do you have fitted. Can you narrow down where the ticking is coming from. Is it there when hot and cold.
Thu Jun 22 2023 7:09am |
Tanner Member Since: 29 May 2023 Location: Staffs Posts: 10 |
Sorry for the lack of detail.it a 3 ltr sdv6 it started on my drive home from work so warm engine but its there on idle and lower rev range then not sure if it disappears or u just lose the noise but it I creases with the revs and sounds top of engine but could be wrong.i did a video but can't upload it |
Thu Jun 22 2023 7:23am |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 177 |
When did you last do an oil change on it? |
Thu Jun 22 2023 1:15pm |
only had the car 3wks and was serviced prior to that also has full lr service history and is currently on 43k |
Thu Jun 22 2023 1:25pm |
Bought private or dealer?
Thu Jun 22 2023 3:04pm |
The garage isn't local to me but have been helpfull so far with helping sort a local garage to fix it under warranty ...I've tried it again tonight with a cold engine and the noise is exactly the same |
Thu Jun 22 2023 8:41pm |
Id leave it to them then dude if covered under warranty, they'll need to see if theres any codes, misfire etc.
Fri Jun 23 2023 9:40am |
Got to the bottom of the noise just waiting on the full extent of damage but yes it's the crank that's gone it's spun the shell so waiting to here if it's a rebuild or new engine.so much for low miles 40k and full lr history |
Fri Jun 30 2023 9:37pm |
I'm not sure to say whether you've been lucky or unlucky. I do hope that the garage won't mess you about and get defensive, but you having the car only 3 weeks makes your case rather robust. There are quite a few threads on here and the Disco3 forum with all similar failures and what it has cost them either through JLR or privately funded. Others have walked away from the brand and chosen elsewhere. Either way it's a known problem and it is a lottery on whom it will affect. Putting it in perspective though the amount of engines they produced to failures (or reported on forums) would suggest its a low percentage, but still a bitter pill to swallow.
Sat Jul 01 2023 6:54am |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 97 |
I'd reject it and go and find another if you really want one. You could be messed about for ages getting that engine sorted. |
Sat Jul 01 2023 10:22am |
m13lky Member Since: 08 Aug 2016 Location: Scotland Posts: 287 |
As above if it was me I’d reject the car and get a full refund, you will be off the road for months until the replacement engine is fitted and unless it’s done by a JLR specialist there is loads of pitfalls a normal garage can fall into and cause you more problems.
Sat Jul 01 2023 12:31pm |
Well it's been a while and 2 replacement engines later I got it back.original engine the oil pump failed causing the crank to fail .New engine in and after 3mile the bearings on the crank failed and seized now on engine number 3 had it back 3 wk and noticed oil leaking so got under to to look and nothing for 3 minutes then whoosh oil everywhere from back ot the engine right hand side by the turbo .the garage are saying its the oil cooler ..any thoughts as I ain't got much co firenze in this garage but the give 12months guarantee on the engine so its there problem for now |
Fri Sep 29 2023 6:18pm |
