Home > Maintenance & Modifications > ACE pipes |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4866 |
Not being funny, but if you don't know where the leak is how do you know you need the pipes unless I've misunderstood your previous comment about not knowing where it is, and how did you find out you need the pipes? although the pipes corroding are a strong possibility, but it could also be the seals where the pipes fit the valve block, the valve block itself corroded, filter plug 'o' ring etc. until you confirm the actual location of the leak it's difficult to know what you require.
Sat Apr 08 2023 1:18am |
RRAS Member Since: 01 Apr 2023 Location: Northern Ireland Posts: 10 |
Take your point but 2 different mechanics told me it’s the ACE pipes that are leaking and need replacing however I’m not sure exactly where they are leaking |
Sat Apr 08 2023 12:24pm |
