Home > General (L494) > Steering rack failure |
Dobby Member Since: 02 Jan 2018 Location: East Seaxe Posts: 101 |
Hi, everyone, so a bit of an update which might pre useful for someone in the future.
Sun Jan 29 2023 9:57pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
Mon Jan 30 2023 12:00am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
DM, would there be any advantage if this is bit of a common occurrence now to pre-empt it and replace the bolts with 304 or 316 grade stainless steel bolts, although they would eventually corroded but not to the degree of steel ones , might save someone a big bill, only a thought.
Mon Jan 30 2023 3:47am |
I know there were a few places offering this for the Evoque/DS racks
Mon Jan 30 2023 7:09am |
Gulp! More, or less? MY15.5 HSE MY13 110 MY87 90 (ex-mod) (for sale) |
Mon Jan 30 2023 10:59pm |
Much less |
Tue Jan 31 2023 7:49am |
Luke Member Since: 04 Feb 2006 Location: Essex Posts: 49 |
Hi, I have just had this exact same problem on my L405, bolts snapped and the motor fell out, no warnings on dash and the motor was still spinning with each turn of the wheel. My local garage managed to drill out the broken bolts and re attach it but it doesn't work at all now, does anyone know if this now needs some sort of reset? !st Edition RRS S/C, Black on Black.
Wed Feb 01 2023 12:22pm |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 206 |
I remember being at my LR Independent last year and I was chatting about how busy they were with the lad on the front desk stated that they were getting a good few RR with the exact problem as described.He basically said the cheap quality bolts were the problem and blamed LR cost cutting rather than paying that little extra for decent quality bolts. |
Wed Feb 01 2023 4:05pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
I'm surprised that LR are making this a perpetual warranty issue rather than just swapping the bolts out for decent quality items as a one off job. Surely that would be cheaper than dealing with full failures as warranty claims. 2012 SDV6 - it's missing a couple of cylinders
Wed Feb 01 2023 6:57pm |
jcchief Member Since: 28 Jan 2024 Location: manchester Posts: 9 |
Hs anyone noticed the bolts tend to fail in winter and there is no corrosion on the bolts.
Tue Jan 30 2024 12:56pm |
My 2015 range rover sport has the same steering unit as Discovery sport 2015 to 2017 , however its not covered by the fix on failure extended warranty for Evoque 2012-2017 and Disco sport.
Tue Jan 30 2024 1:03pm |
Keep the pressure on LR Customer Service for your case
Tue Jan 30 2024 1:31pm |
Thanks for the suggestion , however i most probably spent 2 hours on the phone with them over last 6 weeks.
Tue Jan 30 2024 2:12pm |
Dragon31 Member Since: 02 Feb 2024 Location: Peebles Posts: 1 |
the same fault has just happened on my Range Rover Vogue (2016). Motor completely detached as all 3 bolts failed. Hate to think what would have happened if I'd been on the motorway or a busy roundabout. Same response from JLR, no recalls on your VIN and you're on your own!
Fri Feb 02 2024 6:25pm |
