Home > Technical > Heater issue |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
Guilty for heater matrix blocking up on these |
Thu Dec 08 2022 9:44pm |
AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 119 |
Ok so what exactly is that and can it be easily corrected ?
Thu Dec 08 2022 9:54pm |
iforland Member Since: 13 Apr 2015 Location: Redditch Posts: 47 |
Very very common...the Land Rover book states that you have to remove the centre console and large parts of the dash (if not the whole thing!!) to remove the internal heat matrix.
Fri Dec 09 2022 10:48am |
Fri Dec 09 2022 10:50am |
I found the message that shows the short cut method to get the matrix out:
Fri Dec 09 2022 10:55am |
Yeah so I think it’s deffo the matrix thing as the air is slightly warm at best and that’s only from the drivers side front and back, I’ve closed the vents off from passenger side as they are cold - Infact I’ve shut them all off and just rely on heated seats.
Sun Dec 11 2022 10:37am |
Alexdc12 Member Since: 18 Dec 2021 Location: Essex Posts: 9 |
If it helps, i just bought the part at that was £142 but i will attempt to fit it myself. I am a little gutted though as the pipes dont have the join in that i was expecting I will have to cut and join with some heater hose i think |
Thu Dec 22 2022 8:58pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Our 05 L320 supercharged had no heating from the passenger side a while ago. Our local garage had it in to sort and they ordered a new matrix but the one that arrived had much longer connecting pies on it which would have meant most of the dash would have to be removed.
Fri Dec 23 2022 8:05am |
Diagnostic machine connected and I get this error code
Sat Jan 14 2023 4:00pm |
