Home > Faults & Fixes > Tdv6 cold start
Who dares wins
Tdv6 cold start
Hello
Just joined the forum and seen plenty of information and helpšŸ‘šŸ» Iā€™ve had a cold start issue below 0 degrees two winters now Iā€™ve replace the sensor which most people say warm with heat or hot water which worked ! Iā€™ve noticed over time when removing engine cover the sound proofing falling off so taken off completely this seemed to have made cold starts harder, I have used roc wall insulation aluminium foil and adhesive foil heat pads wrapped the sensor and secured tidy and next morning the temp -3 after 4 or 5 pre heats started first time hope this could help! This on tdv6 2.7!
Post #629002 Sun Dec 11 2022 10:47am
Stevepd
Cheers any photos. My foam also was coming off the engine cover, so it was removed completely but have not replaced it. I havenā€™t had any issues starting though. Iā€™ve been out this morning to take the dogs out at -4. -9 at 5.30am though. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #629005 Sun Dec 11 2022 12:04pm
I would be more inclined to check your glow/heater plugs are all working, can't think it should take 4-5 pre heat cycles to start.
Post #629019 Sun Dec 11 2022 8:09pm
yeap glow plug issue if it won't start below 0 C
Glowplugs usually snap and can cost Ā£700 to drill out, so this is a cheaper work around.
with a resistor and push button
https://www.disco3.co.uk/forum/topic178409.html
Alternatively fit a remote FBH start to preheat the coolant. Around Ā£100
Post #629020 Sun Dec 11 2022 8:25pm
Who dares wins
Evening
Weā€™ll since Iā€™ve insulated the sensor cold starts been fine no more extra pre heat , interesting that the issue as stopped I can photo if interested but quite simple as long as you keep material away from belts etc! But good heat tape and couple of cables ties done šŸ‘šŸ» just normal pre heat this morning below freezing!
Post #629048 Mon Dec 12 2022 9:24pm
Still starting ?
Post #629156 Thu Dec 15 2022 11:55pm
Who dares wins
Yes starting fine now cheers it was a pain before but a simple fix I should have done last year !! -4 degrees this morning. Some of the colder countries do recommend a couple or so pre heats if unusually cold just to help. Wish Iā€™d taken and done a photos .
Post #629187 Fri Dec 16 2022 8:37pm
Jellis39
This is another fix. Works well in my experience.
Post #629324 Tue Dec 20 2022 11:58pm
