Home > Wheels & Tyres > 255/55/20 - General Grabber AT3 vs Falken Wildpeak AT3WA |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 180 |
I have Grabber AT3 tyres on my L320 in 275/40/r20. Generally very good. Slight loss in handling if pressing on but this is to be expected with an all terrain tyre versus a normal road tyre. Off road the AT3 is generally good but has been defeated by very muddy conditions.
Fri Sep 09 2022 1:59pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
Haven't tried the WildPeak but have run 255/55/19 Grabber AT3 before. Decent tyre that's very good on road for an AT. Good in snow, not great on ice tarmac but then very few tyres are. Would fit them again - might have to if I can't find any 255/55/19 Pirelli Scorpion AT+ in a month or two's time.
Fri Sep 09 2022 7:22pm |
RECC Member Since: 09 Sep 2022 Location: London Posts: 3 |
Thx for tips and comments. Planning to do some guided off-roading tours, mainly. Heading to North Wales in two weeks..
Tue Sep 20 2022 8:33am |
roboreeves Member Since: 25 Oct 2022 Location: Cornwall Posts: 10 |
Silverstone, how have you found the grabbers on wet roads, there is a tyre review that trashes them so I am worried. Have they affected the ride much? My Land Rover specialist sees a lot of RRS with drive train issues with people running larger diameter tyres so says stick with standard sizes. He actually has a RRS parked up with 275/45r20 in his yard waiting for repair. Trouble is the tyre choice is then 275/40r20 or 255/50r19 and the only AT tyre I can find for either is the General Grabber AT3. So I keep my 20" rims and have the same as you or swap to 19" (which I have) and put a set on them. What do you think? Thought the 19 would be the better choice but they will have less rubber on wet tarmac making the braking distances even worse. Plus I will have to have the 19's rims refurbished before I use them so even more money. Advice needed! |
Tue Oct 25 2022 11:21am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
I have run both 275/45 x 20" and 275/45 x 21" on L320 sports for at least the last 10 years and have never had the slightest transmission/drivetrain issues.
Tue Oct 25 2022 11:35am |
Oh my goodness Col I was born in Hawkes Bay!! Parents bought me to UK when I was 6 months old and I have no memory :-/
Tue Oct 25 2022 11:46am |
I have completed about 11,000 miles on the 275/40 x20 (V rated) General Grabber AT3 tyres. On the road the ride is no worse. The only comment would be that if you are driving 'spirited' then the turn-in is not as good as a pure road tyre. As yet, no mechanical issues leading from the fitment of the tyres and the wear is very even. Note though, that I did have the tracking checked and adjusted just after the tyres were fitted. There is no replacement for displacement - W O Bentley
Tue Oct 25 2022 11:48am |
Thanks for reply Silverstone, you have a 5 litre, my definition of spirited might be different from yours hahaha |
Tue Oct 25 2022 12:01pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1049 |
Grabbers are perfectly fine on wet roads, I've never had a problem, particularly if you drive within your limits. I run 255/55/19s, the slightly higher sidewall being better for off-road driving. I've used AT3s for coming up to 40k miles now and the only sidewall issue was getting pushed out by a bus coming into my lane in London and clipping the central reservation |
Tue Oct 25 2022 1:39pm |
Thanks Pufftmw. I will go with the Grabbers. I just need to choose between 275/40r20 and 255/50r19 bearing in mind refurbishing the 19's will add £250 onto the tyre change.
Tue Oct 25 2022 2:05pm |
The 20 inch has less tyre wall and, in my opinion, does compromise the tyre slightly off road compared to a tyre with a taller tyre wall. There is no replacement for displacement - W O Bentley
Tue Oct 25 2022 4:29pm |
255/55/19s all the way. You need a bit of sidewall flex to assist grip, so definitely get the most you can. |
Tue Nov 01 2022 2:30pm |
