Home > In Car Electronics > RR SPORT ELECTRIC WINDOWS
Mantaraman
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
RR SPORT. 2007. L320.
The windows are giving me a problem. The driver's master switch doesn't operate any of the windows. The only switch that works full-time is the front passenger. Very occasionally, the master and individual switches will work but only after the car has run for a short while, certainly not immediately after starting. We've had no rain recently but I've checked anyway - the switches are bone dry. With the driver's door card off, I can shunt across the terminals to make the windows work.
Thinking of trying a replacement switch.
Any suggestions?
Post #625394 Wed Jul 13 2022 3:22pm
usually its the wiring to the door (where it hinges)
and they work with the door open.
But if you bypass the switch and it works, then I think you have proved its the switch
window switch part numbers at the end of this thread
https://www.disco3.co.uk/forum/topic198300-195.html
Post #625398 Wed Jul 13 2022 6:03pm
Mantaraman
Andy K, thanks for the tip. Bought a new (ebay cheap deal) switch but it didn't work. Eventually tried pushing/pulling the buttons and got 3 windows working on the original switch, n/s rear not. Removed the door card, disconnected its individual switch, re-plugged it and the window then worked. 2 days later, all windows are still working. Don't know if there's an ECU for the windows but - with all windows closed - pulling up all 4 buttons on the master switch might have been the answer. Hope you don't need it but this might be worth a try if you get into the same situation.
Post #625635 Sat Jul 23 2022 9:19am
