Home > Technical > Fog lights |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4879 |
Should see something like this under the fuse box lid.
Wed Jun 23 2021 9:52am |
Clowesd Member Since: 24 Mar 2022 Location: West sussex Posts: 10 |
Old thread i know but did you resolve this ? Im having the exact same problem |
Thu Mar 24 2022 6:34pm |
Did you manage to fix this issue ? Mine is the same both no power at either fuses, no fog light symbol on the dash either and i think there should be ? |
Thu Mar 24 2022 6:36pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4817 |
Front and rear not working ?
Thu Mar 24 2022 7:46pm |
Thanks for the reply, both the front and rear not working i have checked and there is no power to fuse f38 and f32 behind the glove box |
Thu Mar 24 2022 8:31pm |
There is a fuse under the bonnet that needs checkin fuse numbe 2 |
Thu Mar 24 2022 9:12pm |
I have checked all fuses in bonnet area and all are ok |
Thu Mar 24 2022 9:38pm |
For 2005-2009 models
Fri Mar 25 2022 1:11pm |
Thanks for the info Andy, i have pulled all the fuses in the engine bay with clear tops, there is no power at all at the brown and purple thick wire behind the switch any other ideas what it could be ? |
Fri Mar 25 2022 3:37pm |
Causing an MOT failure is it ?
Fri Mar 25 2022 3:42pm |
Yes its due an m.o.t. not worried about the fronts |
Fri Mar 25 2022 4:38pm |
Under the bonnet is a square relay R13 (with key icon)
Fri Mar 25 2022 5:18pm |
Fri Mar 25 2022 5:58pm |
Thanks very much ile give it a go and report back |
Fri Mar 25 2022 6:01pm |
