Home > Maintenance & Modifications > Rear brake backing plate replacement… |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4867 |
I believe to change the backplates you have to remove the hubs as well, I don't know if they are available in the UK but you can get a modified backplate kit which is essentially a backplate cut in half which enables you to fit it without removing the hubs, would assume you just need to cut the old one in half to remove unless if falls apart from rust.
Thu Feb 03 2022 10:57pm |
Crp Member Since: 16 Sep 2019 Location: Scotland Posts: 25 |
Thanks Col,
Fri Feb 04 2022 11:02am |
