Home > My Range Rover Sport > Project HST |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4872 |
First picture in the post shows it with a HSE badge on it not HST it now has, so probably dealer version.
Sun Jan 09 2022 8:55pm |
J4XHY Member Since: 14 Feb 2021 Location: South Wales Posts: 20 |
Hi, by standard looking I mean no aftermarket bodykit etc added bits that come on later models . but I see what you meanπ Update soon with non standard parts to modernise interior lol Numberplate - do you mean the shape? Not sure what that's got to do with ocd tho just personal preference? Last edited by J4XHY on Mon Jan 10 2022 10:25am. Edited 2 times in total |
Mon Jan 10 2022 10:21am |
Hi is this common as I haven't read much about it? Timing belts been done on it. I'll definitely look into it thanks |
Mon Jan 10 2022 10:22am |
The advert I've bought from says HST version. Checked logbook and its says HSE. I've also read about a stormer version, how do you know which one it would be? It's 2.7 tdv6 with Brembo brakes, Ace, HST kit but hasn't got the rear diff lock tho |
Mon Jan 10 2022 10:28am |
If it says HSE in the log book then the body kit was fitted after it left the factory, either by a dealer or someone else. I may be wrong but I belive the 2.7 was originaly called a Stormer, the TDV8 3.6 was called the HST.
Mon Jan 10 2022 10:43am |
Ok so haven't updated for a while..
Mon Jan 10 2022 11:03am |
Had some marks / scratches on the leather so decided to refurb myself
Mon Jan 10 2022 11:19am |
Lynchy Member Since: 24 Oct 2021 Location: Newcastle Posts: 80 |
Very nice job your doing here mate. What did you use to refurb the leather. Looks immaculate |
Mon Jan 10 2022 6:51pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4811 |
Usually just after belt change is when the risk is highest Info on differences http://www.disco3.co.uk/gallery/albums/use...sioner.pdf Guide is outdated, but first 2 pictures good for reference |
Mon Jan 10 2022 7:21pm |
That's definitely a job that should be done during belt change then.. Looks a lot of work to do now π Timing belt done by previous owner by LR specialist.. I'll check receipt to see if done or maybe call them π |
Mon Jan 10 2022 11:49pm |
Thanks buddy π she'd only done 55k when I bought her last year (59k now) so seats wasn't bad anyway. I bought scuffmaster leather dye (mixed to correct colour) - I posted them my headrest to get a perfect match. Some leather filler to fill any scratches. Then applied the dye using a airbrush gun on a air compressor. The gun only cost around Β£25. Dye another Β£25 and filler around Β£10. They really do look brand new ππ Just done a set of 192k Range Rover Vougue seats and they look great |
Mon Jan 10 2022 11:56pm |
Thanks for the info Col, appreciate it |
Mon Jan 10 2022 11:58pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8863 |
It was just the letter spacing - it's an OCD thing for me as I'm not a fan. And the police aren't either, it should be noted. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Jan 11 2022 12:52am |
